Is there a solution for a soft type attribute in a object with aSet the "Default Value Display Mode" preference to "Do not display". This preference can be found under "Attribute Handling".
discrete set constraint to have the default value blank or null?
If the attribute is a value required constraint and the default value is
blank or null, then it would force the user to select a value from the
list.
Presently I can not find a method to establish a default value of blank
for a discrete set constraint.
Ray
Ray Drennen
MCAD Administrator
Otis Elevator Company
5 Farm Springs Rd.
Farmington, CT 06032
860-676-5619 - voice
860-353-1356 - eFax
ray.drennen@otis.com <
