I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.0
When trying to create a Vendor Part, i get the error message " organization ... is not a Vendor organization". I am unable to select an organization when creating a part. I created Vendor organizations.
Article - "Getting error while performing "Save As" the WTPart: "<Organization Name> is not a vendor organization" in Windchill PDMLink": https://www.ptc.com/en/support/article/CS370253
Hello JL_10443184,
I'm Charles from PTC Tech Support in Europe: did you check Vladimir's comment?
KR,
Charles Gautier.
