Hi, friends
i am using pro e wf3 in and in that i have a problem while printing in to pdf. if i use true type font every thing is coming correct but the tolerance are not printing correctly. it is printing like the upper tolerance is printing in small size and lower tolerance is printing in large size font. If i use stroke all font the + & - sine are look like same and text also not clear. i used all the font in my system. pl some one help........
Boopathiraj
Uner the "Content" tab, try the setting "Stroke All fonts".
