Forgive me if this has already been asked before but is there a way to remove product from the product side in PDMLink?
Any help is greatly appreciated!
Thanks!
i provided the oid number . it asked me to give the u8 value . i gave . but it says error at line 1 , missing expression. what to do ?
If you don't want to mess with the database, then once you've "cleaned out the product", and removed all Team members, you can simply create a deny all policy rule for the product's domain. It will still be in the db, but no one will be able to see its existence.
Russ
