Hi All,
Do you use any utilities to clean the PC after logging into PLM from public PC? I am thinking about some wraper which will clear cache, passwords e.t.c after using Windchill. Any utilities you would suggest: pros vs cons? How would you even start it since windchill does not have a logout?
Just wanted to start a discussion, and, maybe get PTC thinking about it...
Tank you,
Dmitry
How about using http://en.wikipedia.org/wiki/Privacy_mode ?
In Reply to John Frankovich:
What would be really slick is to have Windchill check for the privacy mode being enabled in the browser. Perhaps something like this: http://crypto.stanford.edu/~collinj/research/incognito/ Not the most bulletproof means, but it works in principle.
If the concern is employee PC access outside of the company network, I would consider a custom browser deployment of Firefox that forces privacy mode. Then force Windchill to check for this browser version.
If you need to ensure secure access from public PCs, I would consider forcing truly public access through Citrix.
John
