under Windchill 8, I have problem with Report manager, when I want to create a new report.
psalaün
When I want to select object, I haven't the full list of object (of my model)  but only a part of the list.
Could you indicate me How Winchill buld this list ?
thank you for your help.
Philippe Salaün
6 REPLIES 6
Philippe,
take a look at this document Resource for reporting
Marco
Hello Marco
but i didn't find any response for me in documents.
In fact, when I run the java applet to see all the type I could select for query builder (under Windchill 8.0), the method getQueryClassNames() (of class ReportTemplateHemper) return only a part of my persistent classes.
I didn't undestand that.
best regards
Philippe
Phillippe,
which browser language did you use when running query builder?
I noticed that this setting change list of selectable type, because of translation.
Marco
Hello Marco,
I used java 1.4.2.17 and for web it's IE8.
Thanck
Marco,
in fact the problem is : whitch service properties files is used by method getQueryClassNames() ?
thank
Phillippe,
I can give you an answer, but maybe you could get it if you ask in this more specific group Windchill Customization
Marco
