update old partner part by new partner name
AA_11007139
i have issue to update the customer name of 1800 customer parts inside widchill leoparts leoni system.
in fact during the running of laoder i received the errors message:
Message|Partner Part Number|old partner ID|new partner ID|is customer
More than one  Customer part found with number[00205143-09-0000]and linked to Customer: SI|00205143-09-0000|999998|TBD--PLASTICOMNIUMLIGHTING|true
the loader is link specific Partner Parts of a given Partner to new one.
so no accept partner part with many version.
please your urgent support
13 REPLIES 13
Can you provide more details? Are you referring to SUMA? I am not sure what you mean by partner parts. Screen shots?
AA_11007139
(To:avillanueva)
partner part i means customer part number in fact i want to update the customer name with saving the same customer part number (same value)
example : actual state
                               the reference "00205143-09-0000" is refer to customer "SI" ( customer code "999998")
                   our target:
the same reference  "00205143-09-0000" should be linked to new customer name "Plastic Omnium Lighting"  (with new customer code "TBD-- PLASTICOMNIUMLIGHTING")
AA_11007139
(To:AA_11007139)
it isn't solved i was typing accept by fault
Hello @AA_11007139,
You have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Still having trouble following. Are you using Manufacturer or Vendor Parts with Supplier management module?
AA_11007139
(To:avillanueva)
it is customer which related to Finish Good (see doc file)
AA_11007139
(To:AA_11007139)
should i use spreadsheet file to apply this update? if yes , could you please provide me the right template
AA_11007139
(To:AA_11007139)
ImportSheetType=PART?
There's an easier way to do this. You can go to Participants administrator and search for the partner's org. From there, you can edit the partner's name and details. This will immediately apply to all parts from that partner!
AA_11007139
(To:joe_morton)
could you please organize meeting to check together the issue
address mail : adel.akrout@leoni.com
I'm sorry I am unable to meet with you. But here are some more specifics to help:
  • We are using the SUMA module (I think you are too). As an example, we have the Supplier McMaster-Carr in Windchill.
  • Here in the Participants Administrator, I searched for McMaster-Carr and I found the Site that got created when the Supplier was created
  • Click on the Site to open it's info. From there, you can click Actions -> Edit Organization
  • The Site's name is editable here. Changing this updates the Supplier name as well.
  • All the parts associated with that Supplier will show the updated name
AA_11007139
(To:joe_morton)
in my case not all of parts are related to the same name
for example the partner "SI" contains 100 parts but i need to update only 40 parts with partner "MB"
is there any solution for this case
"edit common attribute" can help me to do one by one ( in my case approximately i have 592 parts to change)
thanks for your support
Try using "Rename" and change the Organization. This can be done on multiple items at once:
