My files are checked in, and I need to update the revision but they file has a line through it
Hi @LR_9979604
Move your pointer to the red icon .
It shows you the error, and you will get idea where the problem is.
I guess that it is a permission issue because you can see the target state.
PetrH
Means one of two things. You are not in a role authorized to revise the objects, or the objects are in a state that doesn't have a revise transition defined.
Hi @LR_9979604
PetrH
