Can not remove Replica folder, it contains Cached items
Decommissioning a Replica server. Got to the spot where you delete the cache folder and get the following: "Can not remove Replica folder, it contains Cached items.". Force sync has been run, Utilities show zero files in cache, and the SQL command in article CS53215 produces no rows. The SQL command in article CS56569 looks promising (delete from masteredonreplicaitem where ida3a4 = <IDA2A2_OF_FOLDER>). How would I get the IDA2A2 value for the folder? This is Windchill PDMLink 11.1.
