windchill 10.2 Change Notice add/delete participants
More specifically, the question was while in a change notice, under the process tab, how to add or delete participants.
I have been advised by our windchill admin that it is a matter of permissions. With permissions a green plus sign to add,
and a red minus sign to remove will be available.
Um...what specifically was your question?
...You're allowed to set one of your own posts to your own question as the Correct Answer and therefore give yourself account points?
Isn't that a conflict of interest PTC?
It's part of the fun. Until cash is associated to points it doesn't matter in the least.
Well, perhaps for reputation on here. Ah well, good to know at least.
