windchill workflow stuck
Sandy7
Hi Guys,
i am facing workflow stuck issue. it is not moving to next person for approval. image attached.
please help.
Sandeep C.
HelesicPetr
(To:Sandy7)
Hi @Sandy7
You've just jumped over the task , you need to do manually.
The operation "complete" does not call the code again. It just move the process forward.
All the automatization has to be done manually from that finished node.
PetrH
6 REPLIES 6
HelesicPetr
(To:Sandy7)
Hi @Sandy7
If the process is promotion request where the changing state is done automatically to the locked state then the data have to be checked-in not check-out.
Check in the data and create new promotion request.
PetrH
Sandy7
(To:HelesicPetr)
Hi @HelesicPetr ,
it is actually CN. i checked those assembly and drawing. it is in checked in state only.
br,
sandeep
HelesicPetr
(To:Sandy7)
Hi @Sandy7
The error shows different information
It seams that your WF is stacked when it should have changed the states.
You need to open the actual workflow find the node where the wf is stopped and finish the node manually as a administrator
PetrH
Sandy7
(To:HelesicPetr)
Hi @HelesicPetr
i have completed the activity node and the work flow moved ahead (assignee to reviewer) but the objects under resulting object table are still in IN-WORK state.
they should be in under review right?
how to overcome this?
Sandeep C.
HelesicPetr
(To:Sandy7)
Hi @Sandy7
PetrH
Sandy7
(To:HelesicPetr)
sorry for the delay. i asked the reviewer to rework the task back to assignee and let the workflow repeat.
all are good now.
thanks @HelesicPetr for suggestion. keep up the good work 😊
