windu,two questions, ListMultipleState MissingRepresentables
XD_9850992
I am using Windchill PDMLink Release 10.0 and Datecode with CPS M020
场景:Windchill10.0做升级,在Windchill10.0环境上做windu后解决潜在的问题;
问题1:ListMultipleState List objects existing in multiple lifecycle states
查知识库,让运行WinRU任务RepairLCManagedObjectsInMultipleStates,但是在执行winru时没有找到此选项
问题2:MissingRepresentables Testing
查知识库,让运行WinRU任务DeleteMissingRepresentablesDT或DeleteOrphanRepresentation,但是在执行winru时没有找到此选项
Hi @XD_9850992
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
Is the option missing or greyed out? Knowledge base does show that these were available in 9.1 so should be there. If its greyed out, follow this to activate that task in WinRU:
https://www.ptc.com/en/support/article/CS159326?source=search
Knowledge base also indicates this task is not mandatory for upgrades so you could skip it and run it later. I have also seen task in WinRU be called slightly different names so is there anything you see that it is similar to?
Good luck on your upgrade. You have a few hops and upgrades to get current.
Do you install the latest WinDU/WinRU patch? If not, I would suggest to install WinDU/WinRU patch before running the tasks
