wt.manager.ServerLauncher - Starting wt.cache.MasterCacheMonito
KS_9212978
6-Contributor
I have Installed WC12.1 , I started Method server, HTTP Server and Installed WDS 11.2 and start DS as well.. but in the Log file i see this warning " WARN [main] wt.manager.ServerLauncher - Starting wt.cache.MasterCacheMonitor" ( Attached log for reference)
unable to login to Windchill home page and method server doesnt start further.  I updated host file with IP Address full domain name name.
could you please help me with solution.
Thanks for the reply,
I checked wt.pom.jdbc.host, wt.pom.jdbc.port, wt.pom.jdbc.service all are pointed correctly,
Host file is also update correctly. - ipaddress xx.abc.com
I was able to login to db with SSMS
any other fixes.
If anything is not working , please open a support call with PTC.
PTC support person will take a look.
Having a similar issue here ... could you get this already resolved?
'Patrick
Ok, we had a wrong host name in wt.pom.jdbc.host and fixing this resolved the issue.
'Patrick
