Creo new file Windchill OIR not apply (10 sequence)
hello. I would like to use 10-digit numbering when creating a new product in Creo connected to Winchill.
After installing the basic OOTB (Windchill 12.0.2.7), I confirmed that a 10-digit sequence was given when I connected Creo to the server and created a new one without any settings. After modifying Windchill EPMDocument OIR from 10 digits to 5 digits, a 5 digit sequence is given even when creating a new one in Creo. (Confirm that the changes are applied)
However, no number is given at all from the actual operating server that has been used and upgraded for a long time. When you connect Creo to Windchill and create a new file, it is created as prt0001. Even if you import OOTB's EPMDocument OIR and edit it with the operation server EPM OIR, the symptom is the same.
It seems that OIR cannot be applied at all in Creo.
