I need to create a form to insert data How can I do it?
cbarboza
Hi I need to create a form, so you can insert information about a document however I don't know where can I find information.
8 REPLIES 8
Hi Carlos,
You can get started with Help center link for creating Wizards/ forms and processing the information.
http://support.ptc.com/cs/help/windchill_hc/wc100_hc/WCCG_UICust_ConstructWizards_ConstructWizards.html#styler-id1.1.1.4…
Bhushan
Hi I tried to follow the guide however I can't, There is other guide step by a step?
doehr
(To:cbarboza)
You also have a lot of flexibility via the Type and Attribute Manager Layouts.
Let's break it down to the fundamental logical components. What Object type do you want to do this for (e.g. all Document types or something specific) and what kind of information did you want to have users adding when creating/modifying that Document object in the system?
Daryl
asingh
(To:cbarboza)
Hi Carlos,
Can you please elaborate what exactly you are looking for.
Aditya
cbarboza
(To:asingh)
Hi What I need  to do Is when a Workflow start in some part of that workflow a form appear and the user insert some values.
Carlos,
How about creating workflow variables and getting the values from user in the tasks assigned to them and then inserting those to Document IBA's
Bhushan
The problem is that I have to create a Drop Down menu so depends of the value that you select of the drop down menu other drop down appear with other options, and I can't do it this with workflow variables I guess.
tkrieger
(To:cbarboza)
Hey,
wrote this (see attachment, my personal memorize guide) for a maybe similar task/workflow/...
Maybe it helps,
Tobias
P.S. Windchill FRACAS documentation is a p...I...t..A.. 😉
