I'm trying to convert a Mathcad Prime 3.1 file to Mathcad 15, in order to use it for a quiz but the PC I have to do the quiz has Mathcad 15.
Is there a way to do that conversion?
Thanks in advance!
hahahaha
NO!
You can't get prime 3.1 to write 3.0, or 3.0 to write 2.0,
I find it less amusing that Fred, but the answer is the same: no. The only way to convert is to manually retype everything.
Which is a real problem if you don't have 3.1, and therefore can't access the file to see what to retype.
(Sorry, Richard! Yesterday was a bad day at work; Shouldn't have "laughed" at the problem.)
Change the extension to .zip, unzip it, open the resulting file in Notepad, write the MC15 worksheet based on the XML ![]()
Please find this worksheet for Mathcad 15 version in attachment.
