This is the error log
File location : C:\ProgramData\PTC\Mathcad Prime\Logs\Mathcad Prime_Exception_20130201_230335.log
Build Number : 2012.10.04.001
System Culture : en-GB; Current UI Culture : en-GB
Architecture: x86
Exception data:
System.Object:
System.Windows.Markup.XamlParseException: Provide value on 'System.Windows.Baml2006.TypeConverterMarkupExtension' threw an exception. ---> System.Configuration.ConfigurationErrorsException: Configuration system failed to initialize ---> System.Configuration.ConfigurationErrorsException: Root element is missing. (C:\Users\ppal\AppData\Local\PTC\MathcadPrime.exe_Url_q0zjel55lyf53edlitf3ui04fxhv5lfk\2.0.4660.18736\user.config) ---> System.Xml.XmlException: Root element is missing.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.ParseDocumentContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Configuration.XmlUtil..ctor(Stream stream, String name, Boolean readToFirstElement, ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
--- End of inner exception stack trace ---
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.BaseConfigurationRecord.ThrowIfInitErrors()
at System.Configuration.ClientConfigurationSystem.OnConfigRemoved(Object sender, InternalConfigEventArgs e)
at System.Configuration.ConfigurationManager.PrepareConfigSystem()
at System.Configuration.ConfigurationManager.GetSection(String sectionName)
at System.Configuration.PrivilegedConfigurationManager.GetSection(String sectionName)
at System.Net.Configuration.WebRequestModulesSectionInternal.GetSection()
at System.Net.WebRequest.get_PrefixList()
at System.Net.WebRequest.Create(Uri requestUri, Boolean useUriBase)
at System.Net.WebRequest.Create(Uri requestUri)
at MS.Internal.WpfWebRequestHelper.CreateRequest(Uri uri)
at System.Windows.Media.ColorContext.Initialize(Uri profileUri, Boolean isStandardProfileUriNotFromUser)
at System.Windows.Media.ColorContext..ctor(PixelFormat pixelFormat)
at System.Windows.Media.Imaging.BitmapSource.CreateCachedBitmap(BitmapFrame frame, BitmapSourceSafeMILHandle wicSource, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, BitmapPalette palette)
at System.Windows.Media.Imaging.BitmapFrameDecode.FinalizeCreation()
at System.Windows.Media.Imaging.BitmapFrameDecode..ctor(Int32 frameNumber, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, BitmapDecoder decoder)
at System.Windows.Media.Imaging.BitmapDecoder.SetupFrames(BitmapDecoder decoder, ReadOnlyCollection`1 frames)
at System.Windows.Media.Imaging.BitmapDecoder.get_Frames()
at System.Windows.Media.Imaging.BitmapFrame.CreateFromUriOrStream(Uri baseUri, Uri uri, Stream stream, BitmapCreateOptions createOptions, BitmapCacheOption cacheOption, RequestCachePolicy uriCachePolicy)
at System.Windows.Media.ImageSourceConverter.ConvertFrom(ITypeDescriptorContext context, CultureInfo culture, Object value)
at System.Windows.Baml2006.TypeConverterMarkupExtension.ProvideValue(IServiceProvider serviceProvider)
at MS.Internal.Xaml.Runtime.ClrObjectRuntime.CallProvideValue(MarkupExtension me, IServiceProvider serviceProvider)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at System.Windows.Application.LoadComponent(Object component, Uri resourceLocator)
at Spirit.ExtendedCommands.InitializeComponent()
at Spirit.SpiritMainWindow..ctor()
at Spirit.App.PrimeStartup(Object sender, StartupEventArgs e)
at System.Windows.Application.OnStartup(StartupEventArgs e)
at System.Windows.Application.<.ctor>b__1(Object unused)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
Mathcad Prime started at:
11:03:31 02/01/2013
Output of systeminfo.exe utility:
Host Name: PPAL-HP-DOCK
OS Name: Microsoft Windows 8 Pro with Media Center
OS Version: 6.2.9200 N/A Build 9200
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: ppal
Registered Organization: HP
Product ID: 00181-00202-67592-AB893
Original Install Date: 17/11/2012, 8:41:32 PM
System Boot Time: 1/02/2013, 8:34:35 PM
System Manufacturer: Hewlett-Packard
System Model: HP ProBook 6450b
System Type: X86-based PC
Processor(s): 1 Processor(s) Installed.
[01]: x64 Family 6 Model 37 Stepping 5 GenuineIntel ~2667 Mhz
BIOS Version: Hewlett-Packard 68CDE Ver. F.23, 13/06/2012
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
System Locale: en-au;English (Australia)
Input Locale: en-us;English (United States)
Time Zone: (UTC+10:00) Brisbane
Total Physical Memory: 2,991 MB
Available Physical Memory: 887 MB
Virtual Memory: Max Size: 4,975 MB
Virtual Memory: Available: 2,191 MB
Virtual Memory: In Use: 2,784 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \\PPAL-HP-DOCK
Hotfix(s): 50 Hotfix(s) Installed.
[01]: KB2712101_Microsoft-Windows-CameraCodec-Package
[02]: KB2727528
[03]: KB2729462
[04]: KB2736693
[05]: KB2737084
[06]: KB2742614
[07]: KB2742616
[08]: KB2751352
[09]: KB2753842
[10]: KB2756872
[11]: KB2756923
[12]: KB2757638
[13]: KB2758246
[14]: KB2761094
[15]: KB2761226
[16]: KB2761465
[17]: KB2764462
[18]: KB2764870
[19]: KB2768703
[20]: KB2769034
[21]: KB2769165
[22]: KB2769166
[23]: KB2770041
[24]: KB2770660
[25]: KB2770917
[26]: KB2771431
[27]: KB2771744
[28]: KB2771821
[29]: KB2777166
[30]: KB2777294
[31]: KB2778171
[32]: KB2778930
[33]: KB2779030
[34]: KB2779562
[35]: KB2779768
[36]: KB2780342
[37]: KB2780523
[38]: KB2780541
[39]: KB2782419
[40]: KB2783251
[41]: KB2784160
[42]: KB2785094
[43]: KB2785220
[44]: KB2785605
[45]: KB2788261
[46]: KB2788350
[47]: KB2790920
[48]: KB2792009
[49]: KB2792476
[50]: KB2796096
Network Card(s): 3 NIC(s) Installed.
[01]: Intel(R) Centrino(R) Advanced-N 6200 AGN
Connection Name: WiFi
DHCP Enabled: Yes
DHCP Server: 192.168.1.254
IP address(es)
[01]: 192.168.1.101
[02]: fe80::f5b8:b608:90e3:8d2f
[02]: Intel(R) 82577LC Gigabit Network Connection
Connection Name: Local Area Connection
Status: Media disconnected
[03]: Bluetooth Device (Personal Area Network)
Connection Name: Bluetooth Network Connection
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: No
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
The following files are being opened:
Dump of system environment variables:
HOMEPATH=\Users\ppal
COMPUTERNAME=PPAL-HP-DOCK
TMP=C:\Users\ppal\AppData\Local\Temp
QTJAVA=C:\Program Files\Java\jre7\lib\ext\QTJava.zip
CLASSPATH=.;C:\Program Files\Java\jre7\lib\ext\QTJava.zip
PROCESSOR_REVISION=2505
PATHEXT=.COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
USERDOMAIN_ROAMINGPROFILE=PPAL-HP-DOCK
TEMP=C:\Users\ppal\AppData\Local\Temp
LOCALAPPDATA=C:\Users\ppal\AppData\Local
PUBLIC=C:\Users\Public
RoxioCentral=c:\Program Files\Common Files\Roxio Shared\10.0\Roxio Central36\
USERDOMAIN=PPAL-HP-DOCK
Path=C:\Program Files\Common Files\MICROSOFT SHARED\WINDOWS LIVE;C:\WINDOWS\SYSTEM32;C:\WINDOWS;C:\WINDOWS\SYSTEM32\WBEM;C:\WINDOWS\SYSTEM32\WINDOWSPOWERSHELL\V1.0\;C:\PROGRAM FILES\COMMON FILES\ROXIO SHARED\DLLSHARED\;C:\PROGRAM FILES\COMMON FILES\ROXIO SHARED\10.0\DLLSHARED\;C:\PROGRAM FILES\ACTIVIDENTITY\ACTIVCLIENT\;C:\PROGRAM FILES\HEWLETT-PACKARD\DRIVE ENCRYPTION\;C:\PROGRAM FILES\MICROSOFT NETWORK MONITOR 3\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\WIDCOMM\Bluetooth Software\
BTK_WIN_TRACEBACK:8292=5d04afb0
PROCESSOR_LEVEL=6
PROCESSOR_IDENTIFIER=x86 Family 6 Model 37 Stepping 5, GenuineIntel
BTK_ROOT_CTX:8292=5caf5d0
PSModulePath=C:\WINDOWS\system32\WindowsPowerShell\v1.0\Modules\
NUMBER_OF_PROCESSORS=4
CommonProgramFiles=C:\Program Files\Common Files
PCBRAND=b
asl.log=Destination=file
ProgramData=C:\ProgramData
FP_NO_HOST_CHECK=NO
OnlineServices=Online Services
Platform=BNB
SESSIONNAME=Console
SystemRoot=C:\WINDOWS
LOGONSERVER=\\PPAL-HP-DOCK
USERPROFILE=C:\Users\ppal
EMC_AUTOPLAY=c:\Program Files\Common Files\Roxio Shared\
PTSM_install_path=C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\Bin
APPDATA=C:\Users\ppal\AppData\Roaming
HOMEDRIVE=C:
BTK_PVTHEAP:8292=5c30000
USERNAME=ppal
PROCESSOR_ARCHITECTURE=x86
OS=Windows_NT
ComSpec=C:\WINDOWS\system32\cmd.exe
SystemDrive=C:
windir=C:\WINDOWS
ALLUSERSPROFILE=C:\ProgramData
The following Modules were loaded by Mathcad Prime:Module Name: MathcadPrime.exe
File: C:\Program Files\PTC\Mathcad\Mathcad Prime 2.0\MathcadPrime.exe; InternalName: MathcadPrime.exe; OriginalFilename: MathcadPrime.exe; FileVersion: 2.0.4660.18736; FileDescription: Mathcad Prime; Product: Mathcad Prime; ProductVersion: 2.0.4660.18736; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: Language Neutral;
Module Memory Size: 311296
Module Name: ntdll.dll
File: C:\WINDOWS\SYSTEM32\ntdll.dll; InternalName: ntdll.dll; OriginalFilename: ntdll.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: NT Layer DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1470464
Module Name: MSCOREE.DLL
File: C:\WINDOWS\SYSTEM32\MSCOREE.DLL; InternalName: mscoree.dll; OriginalFilename: mscoree.dll; FileVersion: 4.0.41209.0 (Main.041209-0000); FileDescription: Microsoft .NET Runtime Execution Engine; Product: Microsoft® .NET Framework; ProductVersion: 4.0.41209.0; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 303104
Module Name: KERNEL32.dll
File: C:\WINDOWS\system32\KERNEL32.dll; InternalName: kernel32; OriginalFilename: kernel32; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows NT BASE API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 1015808
Module Name: KERNELBASE.dll
File: C:\WINDOWS\system32\KERNELBASE.dll; InternalName: Kernelbase.dll; OriginalFilename: Kernelbase.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows NT BASE API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 774144
Module Name: ADVAPI32.dll
File: C:\WINDOWS\system32\ADVAPI32.dll; InternalName: advapi32.dll; OriginalFilename: advapi32.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Advanced Windows 32 Base API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 712704
Module Name: msvcrt.dll
File: C:\WINDOWS\system32\msvcrt.dll; InternalName: msvcrt.dll; OriginalFilename: msvcrt.dll; FileVersion: 7.0.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows NT CRT DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 7.0.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 724992
Module Name: sechost.dll
File: C:\WINDOWS\SYSTEM32\sechost.dll; InternalName: sechost.dll; OriginalFilename: sechost.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Host for SCM/SDDL/LSA Lookup APIs; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 212992
Module Name: RPCRT4.dll
File: C:\WINDOWS\system32\RPCRT4.dll; InternalName: rpcrt4.dll; OriginalFilename: rpcrt4.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Remote Procedure Call Runtime; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 860160
Module Name: mscoreei.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\mscoreei.dll; InternalName: mscoreei.dll; OriginalFilename: mscoreei.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: Microsoft .NET Runtime Execution Engine; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 499712
Module Name: SHLWAPI.dll
File: C:\WINDOWS\system32\SHLWAPI.dll; InternalName: SHLWAPI; OriginalFilename: SHLWAPI.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Shell Light-weight Utility Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 262144
Module Name: USER32.dll
File: C:\WINDOWS\system32\USER32.dll; InternalName: user32; OriginalFilename: user32; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Multi-User Windows USER API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 1183744
Module Name: GDI32.dll
File: C:\WINDOWS\system32\GDI32.dll; InternalName: gdi32; OriginalFilename: gdi32; FileVersion: 6.2.9200.16433 (win8_gdr.121010-1704); FileDescription: GDI Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16433; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1089536
Module Name: IMM32.DLL
File: C:\WINDOWS\system32\IMM32.DLL; InternalName: imm32; OriginalFilename: imm32; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Multi-User Windows IMM32 API Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 176128
Module Name: MSCTF.dll
File: C:\WINDOWS\system32\MSCTF.dll; InternalName: MSCTF; OriginalFilename: MSCTF.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: MSCTF Server DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 905216
Module Name: FileMonitor32.dll
File: C:\windows\system32\FileMonitor32.dll; InternalName: ; OriginalFilename: ; FileVersion: ; FileDescription: ; Product: ; ProductVersion: ; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: ;
Module Memory Size: 122880
Module Name: SHELL32.dll
File: C:\WINDOWS\system32\SHELL32.dll; InternalName: SHELL32; OriginalFilename: SHELL32.DLL.MUI; FileVersion: 6.2.9200.16451 (win8_gdr.121105-1502); FileDescription: Windows Shell Common Dll; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16451; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 17588224
Module Name: ole32.dll
File: C:\WINDOWS\system32\ole32.dll; InternalName: OLE32.DLL; OriginalFilename: OLE32.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft OLE for Windows; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1150976
Module Name: combase.dll
File: C:\WINDOWS\SYSTEM32\combase.dll; InternalName: COMBASE.DLL; OriginalFilename: COMBASE.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft COM for Windows; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1269760
Module Name: SOPHOS~1.DLL
File: C:\PROGRA~1\Sophos\SOPHOS~1\SOPHOS~1.DLL; InternalName: sophos_detoured.dll; OriginalFilename: sophos_detoured.dll; FileVersion: 10.0.9.7004; FileDescription: Sophos Buffer Overrun Protection; Product: Sophos Anti-Virus; ProductVersion: 10.0.9; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 229376
Module Name: PSAPI.DLL
File: C:\WINDOWS\system32\PSAPI.DLL; InternalName: PSAPI; OriginalFilename: PSAPI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Process Status Helper; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 24576
Module Name: clr.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clr.dll; InternalName: clr.dll; OriginalFilename: clr.dll; FileVersion: 4.0.30319.18010 built by: FX45RTMGDR; FileDescription: Microsoft .NET Runtime Common Language Runtime - WorkStation; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18010; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 6889472
Module Name: MSVCR110_CLR0400.dll
File: C:\WINDOWS\SYSTEM32\MSVCR110_CLR0400.dll; InternalName: msvcr110_clr0400.dll; OriginalFilename: msvcr110_clr0400.dll; FileVersion: 11.00.50709.17929 built by: FX45RTMREL; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 11 Beta; ProductVersion: 11.00.50709.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 864256
Module Name: mscorlib.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscorlib\81bce73cc3eef6d5a6774a5177323bf8\mscorlib.ni.dll; InternalName: mscorlib.dll; OriginalFilename: mscorlib.dll; FileVersion: 4.0.30319.18010 built by: FX45RTMGDR; FileDescription: Microsoft Common Language Runtime Class Library; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18010; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 16510976
Module Name: CRYPTBASE.dll
File: C:\WINDOWS\SYSTEM32\CRYPTBASE.dll; InternalName: cryptbase.dll; OriginalFilename: cryptbase.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Base cryptographic API DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 36864
Module Name: bcryptPrimitives.dll
File: C:\WINDOWS\SYSTEM32\bcryptPrimitives.dll; InternalName: bcryptprimitives.dll; OriginalFilename: bcryptprimitives.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows Cryptographic Primitives Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 331776
Module Name: uxtheme.dll
File: C:\WINDOWS\system32\uxtheme.dll; InternalName: UxTheme.dll; OriginalFilename: UxTheme.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft UxTheme Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 684032
Module Name: pddlghlp.dll
File: C:\Program Files\Avanquest\PowerDesk\pddlghlp.dll; InternalName: PowerDesk Dialog Helper Hook; OriginalFilename: PDDlgHlp.DLL; FileVersion: 8.5.1.26; FileDescription: PowerDesk Dialog Helper Hook; Product: PowerDesk; ProductVersion: 8.5.1.26; Debug: False; Patched: False; PreRelease: True; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 143360
Module Name: COMCTL32.dll
File: C:\WINDOWS\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_5.82.9200.16384_none_bf100cd445f4d954\COMCTL32.dll; InternalName: COMCTL32; OriginalFilename: COMCTL32.DLL.MUI; FileVersion: 5.82 (win8_rtm.120725-1247); FileDescription: Common Controls Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 552960
Module Name: MSVCP90.dll
File: C:\WINDOWS\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6871_none_50944e7cbcb706e5\MSVCP90.dll; InternalName: MSVCP90.DLL; OriginalFilename: MSVCP90.DLL; FileVersion: 9.00.30729.6871; FileDescription: Microsoft® C++ Runtime Library; Product: Microsoft® Visual Studio® 2008; ProductVersion: 9.00.30729.6871; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 581632
Module Name: MSVCR90.dll
File: C:\WINDOWS\WinSxS\x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.6871_none_50944e7cbcb706e5\MSVCR90.dll; InternalName: MSVCR90.DLL; OriginalFilename: MSVCR90.DLL; FileVersion: 9.00.30729.6871; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2008; ProductVersion: 9.00.30729.6871; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 667648
Module Name: DpoFeedb.dll
File: C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\Bin\DpoFeedb.dll; InternalName: FeedbackHook; OriginalFilename: Dpofeedb.dll; FileVersion: 5.1.0.4249; FileDescription: DigitalPersona OTS Feedback; Product: DigitalPersona Pro; ProductVersion: 5.1.0.4249; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: Language Neutral;
Module Memory Size: 512000
Module Name: OLEAUT32.dll
File: C:\WINDOWS\system32\OLEAUT32.dll; InternalName: OLEAUT32.DLL; OriginalFilename: ; FileVersion: 6.2.9200.16384; FileDescription: ; Product: ; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 569344
Module Name: VERSION.dll
File: C:\WINDOWS\SYSTEM32\VERSION.dll; InternalName: version; OriginalFilename: VERSION.DLL; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Version Checking and File Installation Libraries; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 32768
Module Name: USERENV.dll
File: C:\WINDOWS\SYSTEM32\USERENV.dll; InternalName: userenv; OriginalFilename: userenv.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Userenv; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 110592
Module Name: profapi.dll
File: C:\WINDOWS\SYSTEM32\profapi.dll; InternalName: PROFAPI.DLL; OriginalFilename: PROFAPI.DLL; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: User Profile Basic API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 69632
Module Name: System.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System\4b4df94b5fc59b48c84c89791c483437\System.ni.dll; InternalName: System.dll; OriginalFilename: System.dll; FileVersion: 4.0.30319.18022 built by: FX45RTMGDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18022; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 9932800
Module Name: WindowsBase.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\WindowsBase\20a433a504e31bac22a69db8713b835f\WindowsBase.ni.dll; InternalName: WindowsBase.dll; OriginalFilename: WindowsBase.dll; FileVersion: 4.0.30319.18016 built by: FX45RTMGDR; FileDescription: WindowsBase.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18016; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 3911680
Module Name: CRYPTSP.dll
File: C:\WINDOWS\SYSTEM32\CRYPTSP.dll; InternalName: cryptsp.dll; OriginalFilename: cryptsp.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Cryptographic Service Provider API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 106496
Module Name: rsaenh.dll
File: C:\WINDOWS\system32\rsaenh.dll; InternalName: rsaenh.dll; OriginalFilename: rsaenh.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft Enhanced Cryptographic Provider; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 253952
Module Name: PresentationCore.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\PresentationCore\0e5da70eddcf3788a74dc8fbebeb6269\PresentationCore.ni.dll; InternalName: PresentationCore.dll; OriginalFilename: PresentationCore.dll; FileVersion: 4.0.30319.18016 built by: FX45RTMGDR; FileDescription: PresentationCore.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18016; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 10924032
Module Name: PresentationFramework.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Presentatio5ae0f00f#\6b55500e41ed13f668c8c036795afd28\PresentationFramework.ni.dll; InternalName: PresentationFramework.dll; OriginalFilename: PresentationFramework.dll; FileVersion: 4.0.30319.18016; FileDescription: PresentationFramework.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18016; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: Language Neutral;
Module Memory Size: 18538496
Module Name: System.Xaml.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xaml\0e60c36da126d0a80be942e0f75c2960\System.Xaml.ni.dll; InternalName: System.Xaml.dll; OriginalFilename: System.Xaml.dll; FileVersion: 4.0.30319.18016 built by: FX45RTMGDR; FileDescription: System.Xaml.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18016; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1892352
Module Name: dwrite.dll
File: C:\WINDOWS\SYSTEM32\dwrite.dll; InternalName: DWrite; OriginalFilename: DWrite; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft DirectX Typography Services; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1437696
Module Name: wpfgfx_v0400.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\wpfgfx_v0400.dll; InternalName: wpfgfx_v0400.dll; OriginalFilename: wpfgfx_v0400.dll; FileVersion: 4.0.30319.18010 built by: FX45RTMGDR; FileDescription: wpfgfx_v0400.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18010; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1691648
Module Name: PresentationNative_v0400.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\WPF\PresentationNative_v0400.dll; InternalName: PresentationNative_v0400.dll; OriginalFilename: PresentationNative_v0400.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: PresentationNative_v0400.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 786432
Module Name: clrjit.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\clrjit.dll; InternalName: clrjit.dll; OriginalFilename: clrjit.dll; FileVersion: 4.0.30319.18022 built by: FX45RTMGDR; FileDescription: Microsoft .NET Runtime Just-In-Time Compiler; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18022; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 450560
Module Name: dwmapi.dll
File: C:\WINDOWS\SYSTEM32\dwmapi.dll; InternalName: dwmapi.dll; OriginalFilename: dwmapi.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft Desktop Window Manager API; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 102400
Module Name: System.Core.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Core\dd8711e10e39622d23a8d5e5da65973e\System.Core.ni.dll; InternalName: System.Core.dll; OriginalFilename: System.Core.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 7004160
Module Name: System.Drawing.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Drawing\efb8a12d6436b16812746ff9d7fc98b8\System.Drawing.ni.dll; InternalName: System.Drawing.dll; OriginalFilename: System.Drawing.dll; FileVersion: 4.0.30319.18022 built by: FX45RTMGDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18022; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1642496
Module Name: DpoSet.dll
File: C:\Program Files\Hewlett-Packard\HP ProtectTools Security Manager\Bin\DpoSet.dll; InternalName: DPoSet; OriginalFilename: DPoSet.dll; FileVersion: 5.1.0.314; FileDescription: Settings Implementation; Product: HP ProtectTools Security Manager; ProductVersion: 5.1.0.314; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: Language Neutral;
Module Name: SHCORE.dll
File: C:\WINDOWS\system32\SHCORE.dll; InternalName: SHCORE; OriginalFilename: SHCORE.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: SHCORE; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 479232
Module Name: WindowsCodecs.dll
File: C:\WINDOWS\SYSTEM32\WindowsCodecs.dll; InternalName: WindowsCodecs; OriginalFilename: WindowsCodecs; FileVersion: 6.2.9200.16420 (win8_gdr.120919-1813); FileDescription: Microsoft Windows Codecs Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16420; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1335296
Module Name: btmmhook.dll
File: C:\Program Files\WIDCOMM\Bluetooth Software\btmmhook.dll; InternalName: BtMmHook; OriginalFilename: BtMmHook.dll; FileVersion: 12.0.0.4300; FileDescription: Multimedia Keys Hook DLL; Product: Bluetooth Software; ProductVersion: 12.0.0.4300; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 221184
Module Name: ReachFramework.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\ReachFramework\23147b7071b1eb8915573646a63d3f85\ReachFramework.ni.dll; InternalName: ReachFramework.dll; OriginalFilename: ReachFramework.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: ReachFramework.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 2846720
Module Name: Ptc.License.Plpf.dll
File: C:\Program Files\PTC\Mathcad\Mathcad Prime 2.0\Ptc.License.Plpf.dll; InternalName: ; OriginalFilename: ; FileVersion: ; FileDescription: ; Product: ; ProductVersion: ; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: ;
Module Memory Size: 4829184
Module Name: NETAPI32.dll
File: C:\WINDOWS\SYSTEM32\NETAPI32.dll; InternalName: NetApi32.DLL; OriginalFilename: NetApi32.DLL; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Net Win32 API DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 73728
Module Name: WS2_32.dll
File: C:\WINDOWS\system32\WS2_32.dll; InternalName: ws2_32.dll; OriginalFilename: ws2_32.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows Socket 2.0 32-Bit DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 327680
Module Name: COMDLG32.dll
File: C:\WINDOWS\system32\COMDLG32.dll; InternalName: comdlg32; OriginalFilename: comdlg32.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Common Dialogues DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 561152
Module Name: MSVCR100.dll
File: C:\WINDOWS\SYSTEM32\MSVCR100.dll; InternalName: msvcr100_clr0400.dll; OriginalFilename: msvcr100_clr0400.dll; FileVersion: 10.00.40219.325; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2010; ProductVersion: 10.00.40219.325; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 782336
Module Name: MSVCP100.dll
File: C:\WINDOWS\SYSTEM32\MSVCP100.dll; InternalName: msvcp100.dll; OriginalFilename: msvcp100.dll; FileVersion: 10.00.40219.325; FileDescription: Microsoft® C Runtime Library; Product: Microsoft® Visual Studio® 2010; ProductVersion: 10.00.40219.325; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 430080
Module Name: WINSPOOL.DRV
File: C:\WINDOWS\SYSTEM32\WINSPOOL.DRV; InternalName: winspool.drv; OriginalFilename: winspool.drv.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows Spooler Driver; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 393216
Module Name: MPR.dll
File: C:\WINDOWS\SYSTEM32\MPR.dll; InternalName: mpr.dll; OriginalFilename: mpr.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Multiple Provider Router DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 77824
Module Name: netutils.dll
File: C:\WINDOWS\SYSTEM32\netutils.dll; InternalName: NETUTILS.DLL; OriginalFilename: NETUTILS.DLL; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Net Win32 API Helpers DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: srvcli.dll
File: C:\WINDOWS\SYSTEM32\srvcli.dll; InternalName: SRVCLI.DLL; OriginalFilename: SRVCLI.DLL; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Server Service Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 114688
Module Name: wkscli.dll
File: C:\WINDOWS\SYSTEM32\wkscli.dll; InternalName: WKSCLI.DLL; OriginalFilename: WKSCLI.DLL; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Workstation Service Client DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 65536
Module Name: NSI.dll
File: C:\WINDOWS\system32\NSI.dll; InternalName: nsi.dll; OriginalFilename: nsi.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: NSI User-mode interface DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: System.Configuration.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Configuration\7401a5b8056a9c3641b277d7193c43bf\System.Configuration.ni.dll; InternalName: System.Configuration.dll; OriginalFilename: System.Configuration.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: System.Configuration.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 962560
Module Name: urlmon.dll
File: C:\WINDOWS\system32\urlmon.dll; InternalName: UrlMon.dll; OriginalFilename: UrlMon.dll.mui; FileVersion: 10.00.9200.16384 (win8_rtm.120725-1247); FileDescription: OLE32 Extensions for Win32; Product: Windows® Internet Explorer; ProductVersion: 10.00.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Name: iertutil.dll
File: C:\WINDOWS\system32\iertutil.dll; InternalName: IeRtUtil.dll; OriginalFilename: IeRtUtil.dll.mui; FileVersion: 10.00.9200.16384 (win8_rtm.120725-1247); FileDescription: Run time utility for Internet Explorer; Product: Windows® Internet Explorer; ProductVersion: 10.00.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 1703936
Module Name: WININET.dll
File: C:\WINDOWS\system32\WININET.dll; InternalName: wininet.dll; OriginalFilename: wininet.dll.mui; FileVersion: 10.00.9200.16384 (win8_rtm.120725-1247); FileDescription: Internet Extensions for Win32; Product: Windows® Internet Explorer; ProductVersion: 10.00.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 1806336
Module Name: Secur32.dll
File: C:\WINDOWS\SYSTEM32\Secur32.dll; InternalName: secur32.dll; OriginalFilename: secur32.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Security Support Provider Interface; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: SSPICLI.DLL
File: C:\WINDOWS\SYSTEM32\SSPICLI.DLL; InternalName: sspicli.dll; OriginalFilename: sspicli.dll; FileVersion: 6.2.9200.16420 (win8_gdr.120919-1813); FileDescription: Security Support Provider Interface; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16420; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: System.Xml.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Xml\da6c54f53b523a6cdb0a1316e1aae820\System.Xml.ni.dll; InternalName: System.Xml.dll; OriginalFilename: System.Xml.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 7569408
Module Name: PresentationFramework.Luna.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Presentatio1c968d57#\1e8d36d3ac3883e3dfbe1e530741d767\PresentationFramework.Luna.ni.dll; InternalName: PresentationFramework.Luna.dll; OriginalFilename: PresentationFramework.Luna.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: PresentationFramework.Luna.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 675840
Module Name: mscms.dll
File: C:\WINDOWS\SYSTEM32\mscms.dll; InternalName: MSCMS.DLL; OriginalFilename: MSCMS.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft Colour Matching System DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 507904
Module Name: PresentationFramework.Aero.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Presentatio1c9175f8#\a6aacbf7660c49f7040b7a88a0292765\PresentationFramework.Aero.ni.dll; InternalName: PresentationFramework.Aero.dll; OriginalFilename: PresentationFramework.Aero.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: PresentationFramework.Aero.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 471040
Module Name: PresentationFramework.Aero2.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\Presentatioaec034ca#\8af0ee136f0c82da9394928b3bd7227d\PresentationFramework.Aero2.ni.dll; InternalName: PresentationFramework.Aero2.dll; OriginalFilename: PresentationFramework.Aero2.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: PresentationFramework.Aero2.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 475136
Module Name: WindowsFormsIntegration.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\WindowsForm0b574481#\b7336397dc98100b138150f4f8c8d54c\WindowsFormsIntegration.ni.dll; InternalName: WindowsFormsIntegration.dll; OriginalFilename: WindowsFormsIntegration.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: Windows Presentation Foundation WindowsForms Integration Library; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Name: d3d9.dll
File: C:\WINDOWS\SYSTEM32\d3d9.dll; InternalName: D3D9.dll; OriginalFilename: D3D9.dll; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Direct3D 9 Runtime; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 1789952
Module Name: igdumdx32.dll
File: C:\WINDOWS\SYSTEM32\igdumdx32.dll; InternalName: igdumdx32.dll; OriginalFilename: igdumdx32.dll; FileVersion: 8.15.10.2858; FileDescription: LDDM User Mode Driver for Intel(R) Graphics Technology; Product: Intel Graphics Accelerator Drivers for Windows 7(R); ProductVersion: 8.15.10.2858; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 606208
Module Name: igdumd32.dll
File: C:\WINDOWS\SYSTEM32\igdumd32.dll; InternalName: igdumd32.dll; OriginalFilename: igdumd32.dll; FileVersion: 8.15.10.2858; FileDescription: LDDM User Mode Driver for Intel(R) Graphics Technology; Product: Intel Graphics Accelerator Drivers for Windows 7(R); ProductVersion: 8.15.10.2858; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 6414336
Module Name: PowrProf.dll
File: C:\WINDOWS\SYSTEM32\PowrProf.dll; InternalName: POWRPROF; OriginalFilename: POWRPROF.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Power Profile Helper DLL; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 258048
Module Name: bcrypt.dll
File: C:\WINDOWS\SYSTEM32\bcrypt.dll; InternalName: bcrypt.dll; OriginalFilename: bcrypt.dll.mui; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Windows Cryptographic Primitives Library; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: UIAutomationTypes.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\UIAutomationTypes\9c446b941ab75f9a5b749013875f1f84\UIAutomationTypes.ni.dll; InternalName: UIAutomationTypes.dll; OriginalFilename: UIAutomationTypes.dll; FileVersion: 4.0.30319.17929 built by: FX45RTMREL; FileDescription: UIAutomationTypes.dll; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 196608
Module Name: UIAutomationCore.dll
File: C:\WINDOWS\SYSTEM32\UIAutomationCore.dll; InternalName: UIAutomationCore.dll; OriginalFilename: UIAutomationCore.dll.mui; FileVersion: 7.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Microsoft UI Automation Core; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United Kingdom);
Module Memory Size: 913408
Module Name: clbcatq.dll
File: C:\WINDOWS\SYSTEM32\clbcatq.dll; InternalName: CLBCATQ.DLL; OriginalFilename: CLBCATQ.DLL; FileVersion: 2001.12.10130.16384 (win8_rtm.120725-1247); FileDescription: COM+ Configuration Catalog; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Name: sxs.dll
File: C:\WINDOWS\SYSTEM32\sxs.dll; InternalName: SXS.DLL; OriginalFilename: SXS.DLL.MUI; FileVersion: 6.2.9200.16384 (win8_rtm.120725-1247); FileDescription: Fusion 2.5; Product: Microsoft® Windows® Operating System; ProductVersion: 6.2.9200.16384; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 655360
Module Name: System.Windows.Forms.ni.dll
File: C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\System.Windows.Forms\5b9dd195123c46d344a0a650e1d352c1\System.Windows.Forms.ni.dll; InternalName: System.Windows.Forms.dll; OriginalFilename: System.Windows.Forms.dll; FileVersion: 4.0.30319.18022 built by: FX45RTMGDR; FileDescription: .NET Framework; Product: Microsoft® .NET Framework; ProductVersion: 4.0.30319.18022; Debug: False; Patched: False; PreRelease: False; PrivateBuild: True; SpecialBuild: False; Language: English (United States);
Module Memory Size: 12701696
Module Name: diasymreader.dll
File: C:\Windows\Microsoft.NET\Framework\v4.0.30319\diasymreader.dll; InternalName: diasymreader.dll; OriginalFilename: diasymreader.dll; FileVersion: 11.0.50709.17929 built by: FX45RTMREL; FileDescription: Dia based SymReader; Product: Microsoft® .NET Framework; ProductVersion: 11.0.50709.17929; Debug: False; Patched: False; PreRelease: False; PrivateBuild: False; SpecialBuild: False; Language: English (United States);
Module Memory Size: 868352
What service release of Mathcad Prime 2.0 do you use (F000, M010) and Windows OS are running? Try to contact with PTC's technical support by creating a new "Case", here: http://www.ptc.com/appserver/cs/case/case_logger.jsp or by using "Mathcad Installation & Licensing Support Center":
http://www.ptc.com/support/mathcad_supportCenter.htm
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
The log says "Build Number : 2012.10.04.001", so it has to be Prime2-M010
Later in the we are informed of
Calling Tech Support seems to be more than appropriate in that case.
Nice catch.
