adding text to dimensions using a mapkey
ptc-5009023
hi i'm reseting up the maykeys in creo and in w4 in if you right click a dimension and go into properties. you can add text in front of or bbehind the actual dimension. when i create a mapkey to do that it deletes out everything in there like radius, diameter symbol or quantity. how do i correctly make a mapkey to add text to a dimension without it replacing whats already there.
side note previous versions you could add it to the prefixx or suffix and after you clicked ok it would move over to the text box. in creo it stay in the prefixx or suffix box. this is how we did this mapkey in previous versions..^^^
thanks!
7 REPLIES 7
Dale_Rosema
(To:ptc-5009023)
Since Mapkeys record your key strokes, you may want to try right or left arrow depending upon whether the text is being placed before or after the dimension text.
it was a good idea but it still deletes everything out...
ø @d ref (2) so i want to add all the extra notes before and in front the dimension (@D) using different keystrokes for each like di for diameter symbol and re for ref.
Thanks!!
you could set a mapkey to add text to the prefix and suffix and it won't delete but then you can't double up otherwise it will delete what you have in the preffix or suffix.
BUMP!!!!
Dale_Rosema
(To:ptc-5009023)
Aaron,
Didn't know if you saw today discussion:
http://communities.ptc.com/message/200142#200142
Maybe this would help what you are looking for.
Mapkeys can be as simple or complex as you want.
As you indicate you already seem to have planned longer input strings so you can EA??
eaDI for adding Diam Symbol or eaRE to add the () for Ref Dims or use Parenthesize Ref Dims option
this allows you to get reaally specific with what each does which is good.
Important to note are the following radio button controlled options.
When recording the Mapkey there are 3 options for what to do at prompts * indicates default setting
(*) Record keyboard input
( ) Accept system defaults
( ) Pause for keyboard input
Choosing the lowest option may solve the delete issue you are having with your mapkeys.
Check to see if this helps fix your problem. I usually use the pause option but never really investigated the others too much. You can always edit the mapkey via a text editor to fix the auto recorded stuff. Also adding pauses into the mapkey can allow user to remove unwanted text as they play through the mapkey. Dales posted link to the other post of mine gives more info in regard to Mapkey Pauses.
Michael
Dale_Rosema
(To:mjcole_ptc)
Michael
Was the bottom one supposed to be (P)? if not, what is the difference between the second and third (lowest) options?
Thanks, Dale
