Hi
Im trying to upgrade some old VB.NET applications to Creo 2.0
When adding the new Creo Parametric Type Library to my project i get into some problems.
Where is the pfcls namespace?
Has it been replaced with the pfc namespace?
Where is the IpfcAsyncConnection class?
What am i missing here??, has PTC changed the VB API without updating the documentation??
Why to change the namespace name, I have to update all my code?
Anyone can help on this changes?
Accordingly do vbug.pdf manual distributed with Creo:
To register the COM server, run the
vb_api_register.bat file located at <creo_loadpoint>/Parametric/bin
Try to run this bat file and all class libraries for VBA should return as expected.
Beware that with Creo2 you need a custom installation to include VB support.
Hope this helps,
I confirm that the option is available in a custom installation of CREO 2.0 form DVD
