Hi all,
I am trying to create a Report table for my assembly using Repeat region. The assembly components are not of the same material and hence have different weight .I want the table to show the weight of each component used in the assembly. Can it be done using Repeat Region? Please help me out.
Thank you.
Shashi.
asm.mbr.pro_mp_mass
