6-Contributor
May 5, 2026
Select Components by Rigid Body # and Rename Rigid Bodies
  • May 5, 2026
  • 2 replies
  • 40 views
Hello everyone,
I am working with a Creo Mechanism assembly and I would like to better understand how to manage the rigid bodies automatically generated by Mechanism.
In the Model Tree, I can display a column called “Rigid Body #”. The components have values such as: Ground123, and Excluded.
I have two questions:
  1. Is there a way to select all components that belong to the same Rigid Body #?
    For example, can I automatically select all components where Rigid Body # = 2?
  2. Is it possible to rename the automatically generated rigid bodies?
    For example, can I change the names from 1, 2, 3 to custom names such as body1, body2, body3, or more meaningful names?
Any suggestion on the recommended Creo workflow would be very helpful.
Thanks!
Fabio
Best answer by FB_14460137
 duplicate of
Community Moderator
May 12, 2026
Hello FB_14460137,
Thank you for your question.
Your post {Select Components by Rigid Body # and Rename Rigid Bodies | Community} has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
FB_144601376-ContributorAuthorAnswer
6-Contributor
May 12, 2026
 duplicate of
