11-Garnet
May 6, 2026 5:59 AM UTC
Fail to get the Datum Plane handle using ProModelItemInit or ProModelItemByNameInit
Hi, I am trying to get the datum plane handle (FRONT plane) use ProModelItemInit or ProModelItemByNameInit but it is failing.
the reason is I want to use ProSelectionAlloc
Can some one please help me with it.
Thank you.
11-Garnet
May 13, 2026 7:29 AM UTC
// this is the function that I created to get the return as ProSelection plane_sel and Datum plane ID (note it doenst give feature ID it gives datum plane ID).
// this we can use it in the API where we want ProSelection as datum plane or int plane id.
// for theory read the API docs for datum plane, in short they are treated as PRO_SURFACE in the CREO.
// here's the function
ProError err = GetPlaneSelectionFromFeatureID(drw_solid_mdl, 1, &plane_sel, &plane_surface_id);
// START OF PLANE SURFACE ACTION FUNCTION
static ProError PlaneSurfaceAction(ProGeomitem* p_handle, ProError status, ProAppData app_data) {
// Skip inactive geometry
ProBoolean inactive;
status = ProGeomitemIsInactive(p_handle, &inactive);
if (status != PRO_TK_NO_ERROR)
return PRO_TK_NO_ERROR;
if (inactive == PRO_B_TRUE)
// Output selection
ProSelection* out_sel = (ProSelection*)app_data;
// Create selection
status = ProSelectionAlloc(NULL, (ProModelitem*)p_handle, out_sel);
if (status == PRO_TK_NO_ERROR)
logger::log_info("Plane selection allocated.");
return PRO_TK_USER_ABORT;
ProError GetPlaneSelectionFromFeatureID(ProSolid solid, int feature_id, ProSelection* out_selection, int* out_surface_id) {
// Init feature
ProFeature plane_feat;
ProError err = ProFeatureInit(solid, feature_id, &plane_feat);
error_utils::CheckError(err, "ProFeatureInit");
if (err != PRO_TK_NO_ERROR)
return err;
// Temp data structure
struct PlaneData
ProSelection* selection;
int* surface_id;
PlaneData data;
data.selection = out_selection;
data.surface_id = out_surface_id;
// Visitor
auto PlaneSurfaceAction = [](ProGeomitem* p_handle, ProError status, ProAppData app_data) -> ProError
// Access data
PlaneData* data = (PlaneData*)app_data;
// Skip inactive
// Surface
ProSurface surface;
status = ProGeomitemToSurface(p_handle, &surface);
// Get surface ID
status = ProSurfaceIdGet(surface, data->surface_id);
logger::log_info("Plane surface ID: " + std::to_string(*(data->surface_id)));
// Create selection
status = ProSelectionAlloc(NULL, (ProModelitem*)p_handle, data->selection);
// Visit geometry
err = ProFeatureGeomitemVisit(&plane_feat, PRO_SURFACE, PlaneSurfaceAction, NULL, &data);
if (err != PRO_TK_USER_ABORT &&
return err;
if (*out_selection == NULL)
return PRO_TK_E_NOT_FOUND;
logger::log_info("Plane selection + surface ID created.");
// END OF PLANE SURFACE ACTION FUNCTION
Emeritus
May 12, 2026 4:49 AM UTC
Hello VP_14440689,
Thank you for your question.
Your post {Fail to get the Datum Plane handle using ProModelItemInit or ProModelItemByNameInit | Community} has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
11-Garnet
May 12, 2026 5:50 AM UTC
I got the solution...@vnamboodheri, thanks for the message
Dale_Rosema
May 12, 2026 2:52 PM UTC
Can you post how you got the solution for someone who reads this post in the future?
VP_1444068911-GarnetAuthorAnswer
11-Garnet
// Output selection
// Create selection
// Init feature
return err;
struct PlaneData
int* surface_id;
PlaneData data;
// Visitor
// Access data
// Skip inactive
// Surface
ProSurface surface;
// Get surface ID
// Create selection
// Visit geometry
return err;
FV_01
May 19, 2026 11:45 PM UTC
I would strongly suggest to use a code sample from Article - CS462524 - How to get geometries in a feature by Creo Parametric TOOLKIT. The code would need to be adjusted to fit specific requirements but the code is clean, uses action and filter functions,  could be referenced in support calls, and most definitely avoids external references
