3D Dragger
dwright-2
3D Dragger
When you first start an assembly whenever you bring a new assembly in it is highlighted a mauve color or dark pink and the 3D Dragger is displayed so that you can position the assemlby you are adding where you want it. After you click OK to accept the addition of the assembly the 3D Dragger is no longer available.
My question is this, is there a way to select an assembly in the model tree that you have brought in to your new assembly and turn the 3D Dragger on again so that you can reposition the assembly?
Doug
The 3D dragger is available when you do a subsequent edit definition.
It has to have at least one degree of freedom available.
2 REPLIES 2
Thanks again Antonius.
