Hello ~
I am a user to use creo 3.0.
Colors assigned to faces disappear if model gets exported to PDF U3D (*pdf) and rotated in Adobe Acobat Reader.
Is there a way to keep the colors?
Thank you.
Config option u3d_create_color_surfaces yes
Thank you very much~
Byoungeun,
Mark the reply from John as Correct Answer as that help you.
