Is there any easy way to get parameters that were created in a drawing into the model? For example if the parameters that a drawing format uses are not in the model, it will create the parameters in the drawing. I would like to pull the drawing parameters back to the model. Relations aren't available in drawing mode, although I did try creating a Drawing Program trying to create a relation DRAWN_BY:0=DRAWN_BY:D but it resulted in an error. I do not see any possible way to get 2D drawing parameters into a 3D model, whether that is a relation, reference, export/import, copy, etc...
the behavior that is causing the issue is that if a parameter type was predefined in the format, and if there is no existing model or drawing level parameter, Creo prompts for the parameter value when creating the drawing level parameter. Ideally there should be an option to create the parameter in the model, to maintain a 3d model based parametric definition, with the model driving the drawing
