Hello.
I find myself having to use Creo Parametric 3.0 without the mouse, so i wanted to ask if it is possible to turn the piece on itself using only the laptop's keyboard and pad, I unfortunately did not find any way
Go to the named views icon in your graphics toolbar and select reorient. Then set it to dynamic orient and you can rotate about x,y, and z of spin center or h, v, and c of screen center.
There is no way to do the same thing that you do with the mouse wheel?
Unfortunately by train I can not use the mouse, travel everyday and I need to work with the creo
You can try going to your control panel and checking your mouse button settings. Some computers without a middle mouse button will let you simulate a middle mouse button by pressing both buttons at once.
