In CREO 5, I am attempting to specify a surface finish symbol to the inside surface of a hole.
1. I have applied the surface finish symbol to the model (everything is getting very MBD now, so I did not apply the symbol to the drawing).
2. I have shown the symbol in the drawing.
3. How do I edit the leader to attach it to the witness line of the hole diameter dimension?
4. Where is the 'all around' modifier in the symbol dialogue box?
Thank you.
OK, after many hours of silence from the community, I have wrestled through this and here is my conclusion:
1. you have to show the surface roughness symbol in the drawing as i mentioned.
2. you click the leader, edit attachment, click the diameter witness line, thennnnn click the geometry of the hole. since the hole is shown on the drawing as 2D, you must click the edge of the hole along its length.
3. remove the arrow head if needed
4. then massage the silly thing until it no longer looks stupid in its default position.
5. regarding the all-around symbol modifier; there may be one, but since it is a hole, I think it is implied. Good enough in the realm of CREO i think.
