What is "AE Propagate" feature?
How can I use it?
.bmp)
On the PTC help I have not found answer.
Hi, this is in help. Use this to propagate annotation within the same model. See below. I attached here a simple model for your reference. Hope this helps.
To propagate outside model, you can select "propagate" option in commands such as publish geometry. Hope this helps.
Thank You very much!
First answer and right answer!
