AE Propagate
gfraulini
AE Propagate
What is "AE Propagate" feature?
How can I use it?
On the PTC help I have not found answer.
Hi, this is in help. Use this to propagate annotation within the same model. See below. I attached here a simple model for your reference. Hope this helps.
To propagate outside model, you can select "propagate" option in commands such as publish geometry. Hope this helps.
gfraulini
(To:BHOoi)
Thank You very much!
First answer and right answer!
