AFX vs Student Edition
MilongueroViejo
I'm teaching myself Creo with version 6.0 student edition.
In trying to work on the framework utility, the system reports that the library parts ( standard beams and the such) were created in a commercial version of Creo and therefore, they are not compatible with the student version.
Is there a way to get around this limitation with a compatible library or even with home-made components that will effectively be compatible with the student version?
Thanks in advance.
Hi @MilongueroViejo
we've recently added support for student version. Please make sure to use Creo 6.0.5.0 with AFX 6.0.5.0.
Hope that helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
Hello there and thanks for the prompt reply.
I have the right version of Creo ( 6.0.5.0) but the AFX version is 6.0.2.0 Lite.
Is there a way to update the AFX only?
Thanks in advance.
Hi @MilongueroViejo
you should have the 6.0.5.0 version in the following folder:
PTC/Creo 6.0.5.0/Common Files/afx
How do you start AFX? Usually if you use the embedded version of Creo then you always have the latest build.
Greetings Sam
Samuel Brantner
B&W Software GmbH
The prt files are where they are supposed to be...under common\afx.
I start afx from the regular assembly interface, framework tab.
The issue is always one of compatibility. The selected beam is properly identified but the file itself seems to be created with the commercial version of the product.
Is there a separate libraries file that can be downloaded to replace the current ones in the afx folder?
Hi @MilongueroViejo ,
I've checked back with PTC Support and it seems that the parts you require are in 6.0.5.1.
Can you get that version and retry?
Greetings Sam
Samuel Brantner
B&W Software GmbH
