All,
Two fold question.
Is there a way to change the default of Relative accuracy (something that PTC has moved away from) when creating a new part in Creo Parametric from Empty?
(We do use templates, but if a User does an import to Empty and does not run ModelCHECK, we can be in danger)
If there a way to remove Empty option when creating a new part from Creo Parametric?
I already know PTC's answer, but didn't know if someone found a customization.
All,
Thank you for the input. It is another PTC fumble.
PTC says this would be considered an enhancement.
Can you run a default script on parts to make all your required settings?
I haven't seen anything that lets you globally set accuracy mode.
Have a look at the following config
intf_in_use_template_models yes
All,
