Add ability to define customize parameter for manufacturing step
OlivierCOUPAT
It would be great to be able to add customized step parametrers in order to ouput in the NCL and use them with the post-processor.
- this could be added in a manufcuring template like:
- These parameters should be avaible for all the steps
- the display and default value could be set in the site (generic, mill, turn, holemaking or WEDM)
- the ouput to the ncl, could be set thru the Parameters UI
This would avoid creating relations for each step or fdu
0 REPLIES 0
