Add custom text in insert field option under text format tab
Sam_Ebenezer97
Hi guys,
to add notes in drawing i am copying text from excel, then pasting it using unattached note. i want to save my custom notes in different names under Insert filed option. to optimize the process.
Is it possible to add custom note under insert filed option. kindly help me on this, if there are any other better option please guide me.
tbraxton
(To:Sam_Ebenezer97)
Save your notes to text files. You can then import the notes from file.
Details on how to implement this method.
To Enter a Note from a File (ptc.com)
Involute Development, LLC
Consulting Engineers
you have to ask PTC Support whether such functionality is implemented.
Martin Hanák
Hi @Sam_Ebenezer97,
You can open a case to contact PTC Support here: https://www.ptc.com/en/support/case-logger?destination=https://support.ptc.com%2Fapps%2Fcase_logger_viewer%2Fcs%2Fauth%2Fssl%2Flog%3F&msg=1.
Best regards,
Catalina
PTC Community Moderator
PTC
