Add new line style to creo 11 drawings
AF_11186485
6-Contributor
Hello everyone,
i am struggling with an issues and need some help. I created new line styles, I create them from "manage line style" and click on "new". I can't use them only in that specific drawing and i want to be able to use in any another drawings. How i can do that?
I was looking to find the file where every default style is (geometry, hidden ecc), where the "line stye gallery" takes from but i am not have been able to find it.
I found this Adding Custom Line Sytles to be used in Detailing - PTC Community and this Article - CS62031 - Is it possible to store *.lsl Line Font files in a specific directory in Creo Parametric
The issues is that i can't find any .lsl file to copy from and know what to write to create this file.
Aboute the template method mentioned in those links, it is possible to define a drawing template with line in it? Maybe i should fine the correct enviroment to create line add them to the options?
Thank you for reading and helping
I think I read in some post on this forum that the only sensible way is to define line styles in drawing templates -AND- then create your production drawings using these templates.
Martin Hanák
Martin Hanák
Hi Martin,
thank you for the answer. I tried it. It seems that create a new template , then create the new line style, will keep it saved when that template is loaded.
