Adding a Dimension parameter as a driving dimensional value in flexibility constrain dialogue box
Ramesh
Anyone could you please tell me, How to add a Dimension parameter as a driving dimensional value in flexibility constrain dialogue box.
TomD.inPDX
(To:Ramesh)
If you are talking about a flexible model in the assembvly tree, then you can create a relation in the assembly and use that as a value in the dialog.
gkoch
(To:Ramesh)
Hello Ramesh, was Antonius' comment the Correct Answer for you? Then please close the thread by marking his post as such. Or, if you had something else in mind, provide a little more details on what you try to achieve. Finally, if you have found an answer to your question yourself, please share it with us. Thanks, Gunter
