Adding model properties to a harness
cfrascona
2-Explorer
Has any one ever needed to report the wight of wire in an assembly?  How do you wight to a cable.  Most wire I've come a crossed give lbs/ft, how can i add this in to be calculated with the assembly?
jstone
(To:cfrascona)
Chuck,
The wires will need the parameters "density", "units", & "mass_units".  density will be a linear density ratio in mass/length (LB/INCH), units will be INCH, & mass_units set to LB.  This should add the wires mass to the model.
jef
2 REPLIES 2
jstone
(To:cfrascona)
Chuck,
jef
Thanks Jef, that worked.
