Does anyone have a good technique they are willing to share about adding BOM balloons.
I use a repeat region and then select Table>Bom ballons> Create Ballon>Show All
Sometimes one won't show up or for some reason or other needs to be shown in a different view.
For this, I use Table>Bom ballons> Create Ballon>Comp & View
If this still doesn't work, I right click on the component in the tree and select Create Balloon.
Kudos to PTC for fixing the ability to do this on flexible components.
Sometimes I cannot get a balloon to show on a patterned component though. Any thoughts?
Got one good response:
"One way to do it is to add a temporary exploded view to the drawing, show all (or just the missing) balloons in that view and them move them to the view you want them in. Then delete the exploded view
I haven't had a problem with balloons on a patterned part, but maybe the first component of the pattern is falling into the "one won't show up for some reason" issue."
Also, I tried ungrouping the pattern and then trying to add the component balloon.
In the end, I just added a fake balloon. Slap my hand with a ruler!
