Hi @PaoloValtorta
Thank you for your question.
Best regards,
I explain my problem with a screenshot.
I import in my DRW a TIFF image and add various 2D entity (lines, notes, quotes, symbols, ecc.).
All entities are visible over the TIFF but only the lines are under it.
If I modify the transparency level of the image can I see they.
When I export my DRW in PDF is all ok.
A partial solution, but only if the TIFF is of good quality, is to set the transparency color to the background of the TIFF in such a way as to remove at least that.
Paolo.
Hi @PaoloValtorta
Best regard,
