An imported TIFF file is over the 2D entities
PaoloValtorta
8-Gravel
I am using Creo Parametric Release 9.0 and Datecode9.0.11.0
When I import a tiff image in my DRW the created dimensions, notes, and symbols appear above the image, while sketch entities appear below, so I have to increase the image's transparency to manage them.
I there a command for put under the image?
Hi @PaoloValtorta
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
I explain my problem with a screenshot.
I import in my DRW a TIFF image and add various 2D entity (lines, notes, quotes, symbols, ecc.).
All entities are visible over the TIFF but only the lines are under it.
If I modify the transparency level of the image can I see they.
When I export my DRW in PDF is all ok.
A partial solution, but only if the TIFF is of good quality, is to set the transparency color to the background of the TIFF in such a way as to remove at least that.
Paolo.
Hi @PaoloValtorta
Best regard,
Catalina
PTC
