Angles in drawings
kboettcher2
Angles in drawings
I am wondering if there is a command to force an angular dimension? My situation is a hole for and ejector pin in a core block, we wire edm 1/2 degree draft as lead in for the pin, but no matter what I do, with angles less than a degree or 2 it wants to put a linear dimension, is there some way to to accomplish this?
4 REPLIES 4
As much as possible Zoom into the area where you will choose the lines to make the angular dimension. Now insert>dimension (click the 2 lines you want the angular dimension between)and place it directly between the 2 lines you just clicked. Then zoom out and drag the dimension to desired location.
Kyle, The config option minimum_angle_dimension sets the minimum angle at which Pro/E will make an angular dimension. Cheers, Tony.
Thank you for the responses guys, Frank, I follow the practice you are describing but with 1/2 degree or less still seems to be a problem. Anthony thanks for that idea, I will give that a try.
