Annotation Notes
AndyHermanson
Annotation Notes
I want to call in a Part name into an Annotation note in the Assembly.
In an assembly drawing, if i activate a part create a note &model_name the note will grab the model name of the active part/assembly and display it in the note. is the a similar way to do this in a model annotation using an FID# or something? I would rather not Manually put stuff in like the second part in the note.
1 REPLY 1
Make a relation with a string variable that is tied to the part's name parameter.
