Hello community,
I'm experiencing hard troubles in translating (...) a MI file into DWG. Several tests made me guess that the problem must come from parts containing Centerline objects. I'm seeking for a way to convert them to geometry, but had no luck up till now. Macro instructions to replace the objects would not do, since I have, for instance, dimensions attached to them. The dxfdwg.con file does not contain any setting about this matter.
Disconsolately thanking for attention,
Marco
What would be the Modeling version you're working in. i thought there where issues with version 19.0 M010 so perhaps you should try updating your modeling version
Hy Ward and thank you: the version is just M010.
As I noticed in recent tests the problem seemed at first to be restricted to the Bolt circle feature: in a simple drawing the creation of a Bolt circle made the translation impossible. But testing on with a complex drawing, I found out the problem persisting until deletion of all Centerlines in details that containded at first Bolt circles too.
At the moment I cannot get version upgrades and must manage the matter in some other way.
