Is there an easy way to calculate the hatched area of a cosmetic sketch?
(other than creating a protrusion of it and measuring it's area)
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
Genius! That works great!
In Reply to Brent Drysdale:
Hi Michael,
Simpler than extruding using the sketch is to highlight the sketch feature
and make a fill (flat surface) then you can get the area or perimeter of the
surface. Does not leave you with a meaningless extrude if you don't need
one. Redefine the sketch and the Fill surface updates automatically. I
would name the fill as an Area feature.
Of course you could pick fill then choose the sketch but that takes a couple
more steps.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
