Area of section
svillafuerte
Area of section
All,
First off, I am using Creo 2.0 M090 if it makes any difference. Anyway, I have someone looking to find the area of the section of where a tube wall meets a cone surface going through it. Attached is a picture of the parts in question but I have not had to try and measure an area that is a radius tube intersecting a radius cone. Can't really do an exact cross section because of the two rounded surfaces. Although, even a cross section through two vertex's tangent to the tube wall may be close enough. So a solution to either of those cases would help out.
Thanks in advance,
Shane V.
Hi Shane,
If you need to know only once then turn the second protrusion into a cut,
leaving only the area you are interested in.
If you need the area measurement to persist, use the surfacing tools in
ProE.
Mark von Huben
Principal Mechanical Engineer
Cochlear Ltd
1 University Ave
Macquarie Park, NSW, 2113
Australia
p +61 2 9425 5210
