hello
Is there an analysis in creo or some addon that can simulate if a component is possible to assemble without interferences with others parts in real assembling process?
E.g. I have an assembly (machine). and now need to assemble a part into the assembly. To put the part in correct place I need to follow
some path and do rotations with the part to avoid collisions with the assembly(I mean this in real, by manufacturing process)).
I can simulate this in creo during assembling the part, manually moving and rotating the part in small steps but it is very difficult.
thanks for help
Michal,
Unfortunately the answer is no, Creo doe snot have assembly feasibility analysis.
- Vlad
The only way I have ever done this is the method you described, using small increments manually moving and rotating the part. There will be nothing "automatic" about this process.
I think not. In mechanism you specify connection between parts...
But here the problem is to find (if it exist) the route from position A to position B without colliding with others parts.
Michal,
- Vlad
