Assembly Curve Pattern not Following Curve
gkarthikyn
Hi, i am having an assembly , which needs to be pattern following  oval curve. when i tried to constraint assembly and pattern it. it goes away from curve on one side. any suggestion how to constraint and how to make the pattern to follow curve
1 REPLY 1
@gkarthikyn
Hard to comment without reviewing the data. However there is an article CS25579 for common curve pattern feature ... this may add some idea.
