Assembly constraint defaulting to "Normal'
dbower1
Even when assemblling something as simple as a bolt, I'll select an 'Axis to Axis' constraint. When I select the 2nd constraint and pick 2 surfaces (Mate), 1/2 the time Creo selects 'Normal', and constraints are invalid.
3 REPLIES 3
TimKnier
(To:dbower1)
I've always wondered this. If Pro/E is trying to helpful by assuming some assembly constraints as you're placing a part in an assembly, why does it sometimes select invalid constraints? You'd think that if the software is making constraint assumptions it would be programmed to only make valid constraint assumptions.
Tim Knier
QG Product & Support Engineering
QuadTech
A Subsidiary of Quad/Graphics
Sussex, Wisconsin
414-566-7439 phone
-<">mailto:->
www.quadtechworld.com<">http://www.quadtechworld.com>
tcooper
(To:dbower1)
Never ASS-u-me that Pro/E will make the right choice, always strengthen
the assumptions, or define your own to firm up your design intent. In
this case flip off the assumption.
Tim P. Cooper
Lead Designer
GE Oil & Gas
North American ATO
T +1 281 878 6168
M +1 281 796 9038
F +1 281 715 4116
- <">mailto:->
www.ge.com
dbower1
(To:dbower1)
Been flipping off a lot of Creo's quirkiness here lately.
In Reply to Tim Cooper:
Tim P. Cooper
Lead Designer
GE Oil & Gas
North American ATO
T +1 281 878 6168
M +1 281 796 9038
F +1 281 715 4116
www.ge.com http://www.ge.com
12221 N. Houston Rosslyn Rd.
PO Box 2291
Houston, TX 77086-3216, USA
GE imagination at work
