How to make fix constraint to multiple items at a time?
AFAIK, not out of the box. I'm sure it can be done by programming using VB or Toolkit or Jlink.
Or 3rd party automation like SmartAssembly, NitroCell or CreoSON.
I made a mapkey that can be run after selecting a component; it replaces its (1st) constraint set with a "fixed" constraint.
Unfortunately, it only works on a single component.
mapkey $F10 @MAPKEY_NAMEReplace 1st constraint set with Fix constraint;\
@MAPKEY_LABELImpose Fix constraint;\
~ Command `ProCmdRedefine`;\
~ Activate `main_dlg_cur` `chkbn.ScrLayout.0` 1;\
~ PopupOver `ScrLayout.1.0` `PH.INST_RMB_.l0` 1 `PH.PIM_chk.l0`;\
~ Activate `ScrLayout.1.0` `PH.DELETE_PB_.l0`;\
~ Select `ScrLayout.1.0` `PH.pop_constr_offset_type` 1 `Fixed`;\
~ Activate `main_dlg_cur` `dashInst0.stdbtn_1`;
Still, it might save you some mouse clicks...
There should be the "Fix Location" command in the right-click menu. Note it is only available if ALL the selected components are unconstrained.
It's already assembled with some other reference. I want to remove that reference and give fix constraint. Is that possible?
you cannot fix constraint to multiple items at a time.
