Assembly constraints
Sachin
7-Bedrock
Hi while assembling a component, in automatic constraining, when we select two flat surfaces of the child and parent components, the constraint type get changed to "Normal" automatically. Can we control this auto-switch to "Coincident" by any means?
7 REPLIES 7
Dale_Rosema
(To:Sachin)
Here are a couple of links to product ideas for this.
http://communities.ptc.com/ideas/1132
http://communities.ptc.com/ideas/1128
Thanks, Dale
Are there any plans set by PTC to work upon these ideas?
StephenW
(To:Sachin)
They are already implemented. Use the following config.pro options:
For eliminating the normal constraint from happening by default:
comp_angle_offset_eps 91
comp_normal_offset_eps -1
Add this option to get it to default to coincident instead of distance:
auto_constr_always_use_offset never
StephenW
(To:Sachin)
Try using these for eliminating the normal constraint from happening by default:
Also, you might add this option to get it to default to coincident instead of distance:
DRFaust
(To:Sachin)
By setting the config options
Assembly works perfect as would expect it to.
Thank you very much
Sachin
7-Bedrock
(To:Sachin)
Steven that is really a good practice..!
I'd argue that depends entirely on what you're modelling. For parts that are a 'matched set', and will only ever be assembled with the others of that one set, it works well. When we model a gearbox casing assembly (so for example a 'bellhousing', maincase and end cover) we model them on a common coordinate system (although not the car coordinate system...)
However, when we model a bearing (to take the other extreme) it would clearly be ridiculous to model it on the gearbox coordinate system, because not only might it be used in more than one position within this gearbox, it may also be used in any number of other gearboxes - some of which may not even have the same shaft orientation (transverse vs longitudinal).
IMO, as soon as there's even a possibility that a component may be used in more than one position, functional constraints (i.e. insert bore on shaft; mate face to abutment) are the only way to go. They also represent design intent, whereas fixing a component at an absolute point in space doesn't...
(I did recently watch a colleague modelling a gearbox with many - if not all - parts on absolute coordinate systems. It looked a royal PITA when he needed to update the position of (what should have been) an assembly, and he was also trying to represent a sliding component - used in two places - in both 'engaged' and 'disengaged' positions!)
