Assembly cut?
Is this a cadidate for an assembly cut?
Actually my parts are both curved, but I thought I state simple with two pieces of tubing, one at a 45 degree angle to the other. The one at the 45 will be cut before being welded to the other (no holes in the parent parent part - just structural). How would you go about making the cut to the 45 degree piece?
The material that needs to be removed in order to nest them together before weld.
